![]() compact stage car buildModerator: is-si Re: compact stage car buildwell that worked , needed to see if i could actually upload photos , the idiots guide worked just fine , starting a build thread , inspired by some of the work on show here , progress is likely to be slow as im only doing weekends due to the lockup being a 50+ mile round trip , this is how she was day 1 , 80k auto drove her back from wincanton , sweet as a nut .
Re: compact stage car build![]() this is how she looked at end of play
Re: compact stage car build![]() getting rid of all brackets and cleaning up seams ready for stitching , sealant removal has got to be the worst , bit surprised though how thin some of the panels are ..will try to upload a few photos together if i can work that one out ...
Re: compact stage car build![]() well that didnt work out as i thought so looks like one at a time ....
Re: compact stage car build![]() so this is my 4th weekend on the car, underbonnet all stitched , boot all flat plated and the pockets in the corners , all brackets inside the car spot drilled out , crush holes welded up , all sealer done , rear arches all tubed ready for the bodykit, hopefully kit and cage will make an apearence soon as my origina l order got " misplaced " is the excuse , so im 3 weeks into my new order , so tomorrow is cut out the doors , mount the h/h/b plate on the tunnel , measure up the beam and get some solid caps turned down ready .....
Re: compact stage car build early finish today it was time for a mega clean up and to take a vanload of bits home thats not going to be used in the build .
Re: compact stage car build choped a bit out of the dash today will need a bit more once the cage is fitted .
Re: compact stage car buildLooking good Denz !!!
Re: compact stage car buildbit of a lazy weekend on the shell , but started doing the loom , after 40+ years in the motor trade i can honestly say ive never seen so many wires ...........panic lol ...
Re: compact stage car build![]() picked this lot up from hockleys today , so it will be hard back at it the weekend ,
Re: compact stage car build![]() done the first cut on the wiring loom , so i need to plug bits in to see what else needs triming , and what still works , ill have to try to get some more inspiration before i have a second go at it .......
Re: compact stage car buildLet me know how you get on with the sump guard, the last Hockley one I saw didn't fit too well
Just by chance Pete do you make/supply sump guards for E36 Compact? If so I would be interested in one for mine. Cheers.
Re: compact stage car buildSorry no Bimsy
Who is onlineUsers browsing this forum: No registered users and 55 guests |
