Jonny Sprinters E30 318iS
Postby is-si » Sat Jan 26, 2008 10:53 pm
This is the beginnings of my mates E30 build. Well not quite, we've been doing odd jobs on it for a while, but this year its come to stay with its Uncle :wink: as time is going on and it needs to built and used by our mate Jonny Sprinter (who looks after the bruv's when we go rallying 8) 8) ).
The rolling shell came pre-caged from ebay :roll: and all that glitters isnt gold especially when you collect it. Turned out it had had a bash at the front and been badly repaired. Since x-mas we've gutted it and cut the creased stuff off the front and put new in, in all the right places (basically all the front forward of the turrets). Weve put in new x-members and inserts for the sump guard and today have put in seat mounts and a platform for a vertical handbrake.
skinned engine mount tabs on x-member (cracks are common on the RHS)
We've got a mint e36 m42 motor out of an e30 318iS that we started to build with lightweight lifters, oversize throttle body and dbilas 280 cams. However a german tried stiffing us with some 256 schricks instead which we found out as soon as we started dummy building/timing. We've eventually been refunded our brass and now need to source some tepid cams and springs etc. We've progressed with oil cooling and baffling as posted on another thread. Engine mounts are as posted on another thread too.
Jonny is well impressed with Kex's 325i so the engine choice may change.
We've had 4.27 and 5.1 multi-plate diffs built up that should sort the gearing out for most venues and main man `kevo' has inspired us to build coilover billies with challenge shocks.
As for brakes we've got 300mm (i think) VAG discs for the front to which we'll add e30 m3 calipers via. an adaptor and at the rear we've got Z1 discs with m3 rear calipers (see e30.de). Jonny went to compbrake in the week and got a bias box to replace the servo.
new bearings in the arms, cut down backplates just to hold the parking brake, just waiting for polybushes for the rear beam.
All for now, hope to get jonny posting progress this year :)
Postby kevo » Sun Jan 27, 2008 3:45 pm
looking very tasty mister, thorough too. keep us posted
Kev
kevo
Postby rearwheelsteercompact » Sun Jan 27, 2008 5:08 pm
kevo wrote:looking very tasty mister, thorough too. keep us posted
Kev
Image One for each of you!Image
Postby M3 Compact » Sun Jan 27, 2008 6:41 pm
Nice one John. :P 8)
Postby bruvs1 » Sun Jan 27, 2008 6:56 pm
between our houses (including our mums!!) weve got an e30 graveyard going on!! :D hopefully the "sister" car shouldn't take too long, hoping to have it painted in a months time, so post i.o.m we can start bolting bits on again :shock: setting goals already!!! :roll:
Postby is-si » Sun Jan 27, 2008 9:49 pm
Its been a good refresher for the bruv's welding and fab. department.
Working on the underside this weekend :( (hopefully) then we'll be on to the "glory jobs" after its painted.... 8)
Postby manxrallyfan » Sun Jan 27, 2008 9:54 pm
Looking good.
Will it be finished for November as I'm sure J.S has unfinished business on the Manx roads.
Andrew Cowley
www.andrewcowley.im
manxrallyfan
Postby is-si » Sun Jan 27, 2008 10:06 pm
That's the plan but watch yourself Andy, Jonny has a habit with aiming his car at the cameramen - have you seen crash 7 :lol:
Postby bruvs1 » Sun Jan 27, 2008 10:11 pm
he's like jimmy cricket without the wellies :lol: !! he has an "L" and an "R" stamped on each glove :shock: :shock:
Postby bruvs1 » Sun Feb 03, 2008 1:48 pm
after another positive saturday on the car ( alcohol fuelled!) :? the underside of the bodyshell is virtually done, weld repairs and strengthening done and a coat of snow (white stone guard) :D so next job is get it rolling for paint, and the bottom pic is the front re-enforced with captivated lugs for sump guard pickup.happy days Image Image
Postby M3 Compact » Sun Feb 03, 2008 8:16 pm
Looking good. 8)
Great pics, liking the snow stuff. :P
Postby bruvs1 » Fri Feb 08, 2008 1:38 pm
bit more graft done on the shell rear arch repairs done and covered with stoneguard also welded up the petrol filler cap as it's getting an alloy tank in the boot. 8) Image
Postby is-si » Fri Apr 18, 2008 10:12 pm
Latest news on this project:
Shell painted inside and out, and assembly started:
Back suspension nearly complete, 280mm Z1 discs with e30 m3 (7series) calipers
E36 m42 Engine progressing too, we matched the ports to the e30 ex. manifold and e30 injectors. Also done a dummy build now with catcams 279/274 cams to measure p-v clearances. Pistons now sent off for bigger cutouts and then balancing. Photos will have to follow (we had time constraints) 8)
Postby jonnysprinter » Thu Apr 24, 2008 3:12 am
bruvs1 wrote:he's like jimmy cricket without the wellies :lol: !! he has an "L" and an "R" stamped on each glove :shock: :shock:
I think you've had one too many sherberts bruvs1 :lol: (or you need to borro' me specs' like :shock: ) as never got confused with Little and Rarge up to now :wink:
Always look on the bright side of life :-)
Stay wuth her johnny - BMW E30 318iS
http://www.utilitywarehouse.org.uk/doyo ... ointheclub
jonnysprinter
Postby bruvs1 » Thu Apr 24, 2008 12:22 pm
:lol: :lol: sherbert is tomorrow night as my local re opens after refurb!! oh happy days!! :D productivity could be slower than usual on saturday :wink:
