M52 2.8 Compact Stage Rally Car (previously 4age/XE )
Postby rearwheelsteercompact » Sun Feb 04, 2007 1:00 am
(My original plan was to put an MR2 engine in the compact. I later decided to install a Vauxhall XE red top instead and finally settled upon the BMW M52 :oops: )
Just to be totally different I am looking into the pro's and cons of fitting an MR2 engine (1.6 4 age) into a Compact, running on Yamaha R1 bike carbs and mated to a Ford rocket (4 speed) gearbox.
Got the Compact - got the engine - got the box - got the carbs - got the enthusiasm (at the moment) 8) all I need now is a magic wand to put them all together.
I like a challenge!!!! :twisted:
Re: BMR2
Postby M3 Compact » Sun Feb 04, 2007 1:28 am
rearwheelsteercompact wrote:Just to be totally different I am looking into the pro's and cons of fitting an MR2 engine (1.6 4 age) into a Compact, running on Yamaha R1 bike carbs and mated to a Ford rocket (4 speed) gearbox.
:shock:
Sounds like a plan. :P
136 BHP? :?: Direct top C/R box and a 4.44 diff with 15" rims. 8)
Re: BMR2
Postby rearwheelsteercompact » Sun Feb 04, 2007 1:32 am
:shock:
Yes, Yes, Yes and Yes :lol: Intend to use oe rims. Already started collecting :wink:
Postby M3 Compact » Sun Feb 04, 2007 10:26 am
Which rims?
Postby rearwheelsteercompact » Sun Feb 04, 2007 12:45 pm
Which rims?
These!
cos I like 'em :) (and easy to find)
Re: BMR2
Postby rearwheelsteercompact » Thu Feb 08, 2007 6:24 pm
rearwheelsteercompact wrote:Got the Compact - got the engine - got the box - got the carbs - got the enthusiasm (at the moment) 8) all I need now is a magic wand to put them all together.
Got the cwp!
I'll post some photo's when I've something to show :wink:
Re: BMR2
Postby M3 Compact » Thu Feb 08, 2007 6:33 pm
Got the cwp!
Are you using a Corolla box?
Re: BMR2
Postby rearwheelsteercompact » Thu Feb 08, 2007 11:29 pm
No - I'm using this little chappie
Ford rocket 4 speed (direct top) dog box :lol: :lol:
Re: BMR2
Postby M3 Compact » Fri Feb 09, 2007 12:07 am
8) 8) 8) (Forgot about Ford box. :oops: )
That's why I was asking. :wink: Have you got a bell housing? (I might know of a Corolla/Ford bell housing.)
Postby rearwheelsteercompact » Fri Feb 09, 2007 12:11 am
The bell housing is still on my lists of wants I'm afraid :cry: . As is a rwd sump :cry:
Postby M3 Compact » Fri Feb 09, 2007 12:14 am
rearwheelsteercompact wrote:The bell housing is still on my lists of wants I'm afraid :cry: . As is a rwd sump :cry:
Is it the same B/H as a Corolla?
Postby rearwheelsteercompact » Fri Feb 09, 2007 12:21 am
I'm pretty sure it is as the 1.6 corolla GT had the 4age engine. But the gearbox side of the BH will be different i.e. Ford fitting.
My mate did one in his MK1 Escort. That was a Corolla bh but used a steel adaptor plate to mate it to the ford box.
You can get a Toyota to Ford bh new - but q. expensive. I'm still researching. :roll:
Postby M3 Compact » Fri Feb 09, 2007 12:25 am
My mate ran an AE86 with type 9 Tranx, he still had the bell housing last I knew, which is why I was asking.
I can find out if he's still got it, if you'd be interested.
Postby rearwheelsteercompact » Fri Feb 09, 2007 12:28 am
Yes please Simon and in the meantime I will check the AE86 bolt pattern. Pretty sure they are the same.
Thank you :lol:
Postby rearwheelsteercompact » Sat Feb 10, 2007 12:04 am
rearwheelsteercompact wrote:Yes please Simon and in the meantime I will check the AE86 bolt pattern. Pretty sure they are the same.
Thank you :lol:
Shown me arse :oops: The AE86 uses the 4age :oops: :roll:
I was thinking the AE86 was an engine type - d'oh
