the one on the door triggers an oil slick and the one near the LCD display arms the missiles
![]() Jonny Sprinters E30 318iSModerator: is-si the other button pokes a red hot poker up your jacksy if you call a wrong un!!!
Re:
No wrong notes called, so the red hot poker has been removed now Always look on the bright side of life
Stay wuth her johnny - BMW E30 318iS http://www.utilitywarehouse.org.uk/doyo ... ointheclub
Re: Jonny Sprinters E30 318iSAfter years of reaching down to the tunnel to pull the handrake Jonny had been struggling to adjust to his new vertical lever
Put some yellow tape on so it stands out too, just for m3compact - i know he likes stickers ![]() ![]()
Re: Jonny Sprinters E30 318iSQuality mod.
Loving the tape.
It took me a while to get used to vertical levers, but I wouldn't go back now. (I use it far too much. So when's the M44 getting fitted?
Very pleased with the mod on the lever and hope I don't have a repeat of my IOM Sartfield Hairpin blunder when we go to Epynt in 2 weeks time. M44 engine will be going in the scrap pile Just finished stripping the 1.6 M43 engine down and the crank and rods are perfect (considering the engine had been left outside with no head on it) Always look on the bright side of life
Re: Jonny Sprinters E30 318iSThe mod on the handbrake lever worked great
Need to take the clutch out and maybe machine the flywheel to get a bit of extra clamping pressure from the cover before its next event as it didn't take kindly to dumping it off the line Always look on the bright side of life
Re: Jonny Sprinters E30 318iSwhat pistons will you use?
Will you use the m42 or m44 head? Interesting!!!
Re: Jonny Sprinters E30 318iSGlad to hear the engine may be of some use, my e30 is off for its cage in the morning. Looks like you had a good run on epynt.
M42 head as it's already been worked on and has some nice CatCams fitted Always look on the bright side of life
The con-rods and crank are in far better condition than I'd expected and only needs a regrind on the thrust bearing face of the crank before being lightened and balanced Glad to hear progress is being made on your car Really enjoyed Epynt thanks and looking forward to going back there again Always look on the bright side of life
The con-rods and crank are in far better condition than I'd expected Adam and only needs a regrind on the thrust bearing face of the crank before being lightened and balanced, thanks again for not scrapping it. Glad to hear progress is being made on your car Really enjoyed Epynt thanks and looking forward to going back there again Always look on the bright side of life
Re: Jonny Sprinters E30 318iSso, what are you doing with the m42 motor then???
Not sure yet, as it does seem a shame to break it up. If you are thinking of aquiring a 1.8 177bhp M42 motor lock stock and barrel, then let me know if you're serious as we would have to build a complete new motor from scratch then? Always look on the bright side of life
Who is onlineUsers browsing this forum: No registered users and 13 guests |
