bruvsmotorworks compact build
Postby ultegra » Sun Oct 11, 2009 11:09 am
I have been taking a dekko at the Harry Hockly website - very high quality worknaship on their project cars. (The blue Escrote with the 300BHP dry-sumped Honda S2000 engine looks like a bit of a tool).
What's the S.P. on fitting the rear flares to the compact? Are they rivetted and bonded or is there some other technique? Do the existing panels need to be joggled?
cheers/
Postby bruvs1 » Sun Oct 11, 2009 5:28 pm
yes , you basically lose the rear arch and then tub the inner to the new arch, hockleys had done it like this, just tagging onto the original inner arch giving it some strength. the new arch sits quite high so it will be all arch and wheels!! :P rivetts and filler seems to be the way for holding it together :)
Postby bruvs1 » Mon Nov 23, 2009 2:00 pm
car still having the cage done, a couple more weeks then its back for christmas, in the meanwhile we've been disecting the m54 :twisted: loads of junk on it but looks promising!!
Postby Tris-m3 » Mon Nov 23, 2009 3:09 pm
What m54 motor is that? a 330??
How much do you pay for one of these harry hockleys tank guards if you don't mind me asking??
Postby bruvs1 » Mon Nov 23, 2009 7:40 pm
basically yes, actually out of a low miler 2002 z3 3.0 roughly a bag and a half for engine, box, rack, loom, all ancillaries, brakes, rear arms, prop. hockleys tank guard was bought with the arch kit available at www.hh-ms.com :wink:
Postby bruvs1 » Sun Nov 29, 2009 2:07 pm
state of play so far, rear turret boxes done, tubes to diff pick up.
cage fitted tightly to the shell
roof section done with added triangulation
couple of weeks before any more progress as jol is back at m sport on the s2000's but v impressed so far :D got some great idea's being put into action in the next installment :wink:
Postby martine30rally » Sun Nov 29, 2009 3:42 pm
nice work, turrets are very similar to the ones i made for my e30, although I made them come up level to the top of the arch in order to run a proper coilover and make the most of its travel
Postby bruvs1 » Sun Nov 29, 2009 5:41 pm
it will take a proper coilover but no point having more than you actually need, :wink: travel won't be an issue it can only move as much as the wishbone. this way it gives us the option of running conventional spring and seperate shocker depending on funds :)
Postby avtovaz » Mon Nov 30, 2009 1:26 am
what mods do you do to the arms where the shock mounts to take the new forces?
I am interested as id love to coil over the rear of mine... Looks easy.
Postby martine30rally » Mon Nov 30, 2009 8:55 am
rear arm doesnt need any work, it worked like that on the group A cars with metally hard spring rates and could handle big jumps, there seems to be some unproven myth that with the bolt in single sheer and a coilover its guaranteed to go bang :?
Postby bruvs1 » Mon Nov 30, 2009 12:21 pm
group A cars had modified rear arms, we'll be using 3.0 z3 rear arms which have minor strengthening, and we'll probably do some extra just to take out the chance eliment. :wink:
Postby Tris-m3 » Mon Nov 30, 2009 1:04 pm
Looks like good work, i don't think i have ever seen such a tight cage!
Postby is-si » Sat Dec 05, 2009 11:35 pm
We've been looking at the M54B30 engine today, and although i'm pro-vanos it has to be ditched mainly because we want it simple. Its always been our intention to fit cams so i'm not over-worried about losing power.
Rather than trying to lock up all the vanos gears we have looked at the original engine design the M50 non vanos. We did a trial build today fitting the m50 cam gear - it all fits together and now looks nice and simple. M50 cam wheels are all slotted so it will be a piece of pi55 to dial in some proper cams 8) .
The Vanos look :( >
The Non-Vanos look :D >
I've looked at the valve gear too, M54 Followers are used in E39 M5's so we think they will suffice our `Phase 1` engine, however the standard valve springs seem to be getting coil bound a bit early. So i've got a yanky S52 valve spring coming for us to measure, (these are the same as M5's too) apparently these address this problem, to what extent though i'm not sure.
Now all the crap is off the motor it looks smart 8) , its certainly not lardy. It will look good polished :oops: :lol: . The crank is a sweet thing too.
It feels like an intrepid voyage of discovery and a fu<king big experiment but here goes....
Postby M3 Compact » Mon Dec 07, 2009 12:27 am
Great stuff.
Really interested in the m54 sans Vanos approach. 8)
[img]Threebagsofpopcorn[/img]
Postby Tris-m3 » Mon Dec 07, 2009 12:50 am
Good to see some serious experimenting going on! 8)
Users browsing this forum: No registered users and 36 guests
