Irish Compact
Re: Irish Compact
Postby BMWIRE » Fri Apr 10, 2009 6:09 pm
After Galway and a Sprint event in September the car was parked up and partially stripped. (Which took from October to January)
All the Rubber bushings in the rear suspension were knackered after 2 rallies and 2 sprints.
Solid bushings were purchased and fitted to the rear beam over the winter.
BMWIRE
Re: Irish Compact
Postby BMWIRE » Fri Apr 10, 2009 6:16 pm
The bushing in the Diff was replaced with a solid one.
The Diff was solidly mounted to the floor and braced inside the car.
Please note could not get a photo of the diff bracing in our car - as the interior is dark green. This photo is from the car we copied. We purchased the solid bushings from the guy that owns this car.
Will try to get photos of our car in brighter weather.
Inspection of the Diff.
BMWIRE
Re: Irish Compact
Postby BMWIRE » Fri Apr 10, 2009 6:23 pm
Also the clutch – which was standard and came with the doner car – was knackered and slipping.
A new Helix Paddle clutch was fitted.
The sump was removed from the engine and the bearings replaced as a precautionary measure.
While we were shopping for the solid bushings we purchased a fibreglass wide arch kit.
Not fitted yet – too scared – might make the car look fast and we did not want to disappoint!!!!!!!!!!!
Kit comprises Front Bumper - 2 Front Wings Complete - Rear Arches and Rear Bumber.
BMWIRE
Re: Irish Compact
Postby BMWIRE » Fri Apr 10, 2009 6:28 pm
Completed on the Birr Stages in February
Finished 50th O/A and 5th in Class
BMWIRE
Re: Irish Compact
Postby BMWIRE » Fri Apr 10, 2009 6:32 pm
Completed on the Mayo Stages in March
Finished 36th O/A and 4th in Class
BMWIRE
Re: Irish Compact
Postby BMWIRE » Fri Apr 10, 2009 6:36 pm
Completed on the Midland Stages in April
Finished 35th O/A and 1st in Class
Thanks to Seamus Conihan, Robert O’Mahoney, Sean Hassett and James Burke for the Action Photos.
BMWIRE
Re: Irish Compact
Postby BMWIRE » Fri Apr 10, 2009 6:39 pm
The rear suspension arms are still rubber bushed which can now be felt in the handling (as we get more used to it).
So we have ordered a set of these, which will make the rear end more solid.
Next Event Planned is at the end of May.
BMWIRE
Re: Irish Compact
Postby is-si » Fri Apr 10, 2009 10:17 pm
Superb post thanks, it looks like you are getting it "engineered" shall we say. 8)
i've a suggestion (you may have thought about it) - its a pity you cant put an insitu adjuster on the outboard rosejoint, to enable you to adjust the rear toe without dropping the beam bolt out. Also may be add a tube between the ends of the trailing arms.
Will you do the front arms group A style next ? :wink:
Keep up the good work . . . :D
Re: Irish Compact
Postby M3 Compact » Sat Apr 11, 2009 11:25 pm
Awesome. 8)
Re: Irish Compact
Postby jonnysprinter » Sun Apr 12, 2009 10:03 am
BMWIRE wrote:Completed on the Midland Stages in April
Brilliant result and nice looking car. 8) Hope you don't lose your fillings from getting rid of all the rubber :wink:
Always look on the bright side of life :-)
Stay wuth her johnny - BMW E30 318iS
http://www.utilitywarehouse.org.uk/doyo ... ointheclub
jonnysprinter
Re: Irish Compact
Postby hsr2.6 » Sun Oct 11, 2009 6:15 pm
Seen the car in action on men and motors today....good to see we're getting on the tv...... :D
Re: Irish Compact
Postby e21Jason » Thu Oct 15, 2009 9:51 am
If you don't mind me asking were did you get the adjsuters from for the rear end
jason
BMW e21 track car supercharged s14 cage and fabrication by http://www.chizfab.com
e36 328 touring lpg for sale
s50'd compact track slag for sale
m88/3 e30 new track slag
Z3M Coupe
69 Alfa spyder
e21Jason
Re: Irish Compact
Postby BMWIRE » Sun Nov 01, 2009 11:49 pm
is-si wrote:Superb post thanks, it looks like you are getting it "engineered" shall we say. 8)
Rear arm full adjustabe along the lines of what you suggest - please read on.
Front Arms is on the list for winter 09/10 - anyone know where they can be sourced????
Thanks for comments.
BMWIRE
Re: Irish Compact
Postby BMWIRE » Sun Nov 01, 2009 11:55 pm
jonnysprinter wrote:Brilliant result and nice looking car. 8) Hope you don't lose your fillings from getting rid of all the rubber :wink:
Never could afford fillings - spent all the money on rallying :D
BMWIRE
Re: Irish Compact
Postby BMWIRE » Mon Nov 02, 2009 12:05 am
e21Jason wrote:If you don't mind me asking were did you get the adjsuters from for the rear end
jason
Got them from a man based in Armagh, Northern Ireland. His name is Gary Toner and he also rallies a compact as per pic below.
He also can manufacture the wide body kit.
Don't have his contact details on me at the mo - can pm it later if you want. He also hires out in-car camera systems on events and i think he has a website - which may have contact details - so google the name 'ALPHACAM'.
BMWIRE
