HSR'S Compact story continues
Re: HSR'S Compact story continues
Postby Daishag » Thu Mar 29, 2012 8:11 pm
BARGAIN !!!!!!!!!!!!
Postby hsr2.6 » Thu Mar 29, 2012 8:13 pm
Daishag wrote:BARGAIN !!!!!!!!!!!!
And i do like the colour, going to pick it up next weekend.........
Postby Daishag » Thu Mar 29, 2012 8:20 pm
Where's it located then bud ??? That was the colour of mine before i stripped it out bud !!!
Postby hsr2.6 » Thu Mar 29, 2012 8:23 pm
Just down from east midlands airport, so fly inn and ferry home.. :D
Postby hsr2.6 » Sat Apr 21, 2012 8:46 pm
Sad news from the garage today, looks like the crank is bent in the engine, it has also sheared the 4 tork bolts on the front pulley. If it's just the crank then it might be up and running by the end of the year, if there's more nastyness in the engine it will be M44 power for the forseeable future... :(
Postby Daishag » Sat Apr 21, 2012 8:59 pm
Steve,
If the crank is bent mate i would buy a 2nd hand bottom end mate and rebuild that i would'nt take the chance it has'nt twisted the block or put a hair line crack on the threads of one of the main cap bolts mate as it would destroy it self 1st time you revved it hard.
Postby hsr2.6 » Sat Apr 21, 2012 10:12 pm
Thats not going to be for a good while Dave, that engine took a real chunk of my money so looks like a couple of years down the line...........
Postby is-si » Sun Apr 22, 2012 11:29 am
Got to say i've been there - I've hit a tree head on in our mint sunbeam, the force took it off the mounts, banana'd the crank, shattered the tran-x box, bent the prop, & bent the S.Brown axle. I dont want to remember the whiplash :oops:
Turn the motor upside down just fit the end journals, and DTI the crank on centre journal
....hope your luck changes 8)
Postby hsr2.6 » Sun Apr 22, 2012 11:31 am
Go idea it'll only move around 45 deg, the front cover is also bent in wards wether that is stopping it i doubt it........
Postby e21Jason » Sun Apr 22, 2012 4:25 pm
My mate had a blown 3.0 bottom end engine lost it's oil in an event so might need a regrind but could be had cheap, unless you want my compact with a s50 already fitted
Jason
BMW e21 track car supercharged s14 cage and fabrication by http://www.chizfab.com
e36 328 touring lpg for sale
s50'd compact track slag for sale
m88/3 e30 new track slag
Z3M Coupe
69 Alfa spyder
e21Jason
Postby hsr2.6 » Sun Apr 22, 2012 4:46 pm
What sort of penny's on both....... :lol:
Postby hsr2.6 » Wed Apr 25, 2012 3:57 pm
Been doing a bit of shopping for the car, being as i've got to stick with the lowly powered M44, i've decided to shed some weight so i bought these.....
All for £250 delivered to Jersey from our Polish freinds, things are so cheap over there at the moment, beacause of the pound against the zloty..........
This whole bodykit including doors.....
£782.............YES........£782
Postby bruvs1 » Wed Apr 25, 2012 7:20 pm
looks good for the money, can you use plastic doors over there? i know they aren't allowed on the mainland. :?
Postby hsr2.6 » Wed Apr 25, 2012 8:56 pm
No you can't as we run under the MSA as well, but under FIA rules you can...........
Postby Tris-m3 » Thu Apr 26, 2012 4:03 pm
hsr2.6 wrote:This whole bodykit including doors.....
Is that for a compact or a coupe?? Its teasing me!!
