![]() liam irish bmw e30Moderator: is-si
• Page 3 of 3 • 1, 2, 3
Re: liam higgins irish bmw e30i got it to fit but i had to put the spacers all underneat the rack and the rack is at an angle too, im goin to get the manifold bent a bit so it would be able to sit better
Re: liam higgins irish bmw e30I had the same problem but i sorted it by mowing the rack about 5mm to the right, it only affected the steering on full lock and it solved all fouling issues.....
Re: liam higgins irish bmw e30o rite, did u drill new holes just 5mm to the right in the cross member brackets?? nd would it matter if the spacers are under neat the rack or would it be better to put them on top
Re: liam higgins irish bmw e30i got that rack thing sorted a few months ago now,i ended cutting a piece out of the manifold and welding in a loop that goes around the column,is it only the 1.6 engines that have this prop when fitting a z3 rack?? i made sure the engine mounts were good too so it wasnt like the engine was sitting down one side or anything.also got a rebuilt 325 L.S.D fitted too and sumpguard.suspensions will be next thing now. i competed in the tynagh rallysprint 14th of march with the car,went nice really enjoyed it
Re: liam higgins irish bmw e30You had the back end floating there! Good stuff Liam .
Re: liam higgins irish bmw e30Cheers Tristan,over floating at times.ill tell ya theres a fare squel from road tyres
Re: liam higgins irish bmw e3014 or 15in? WE'd have some here from the rally cars.
Re: liam higgins irish bmw e3015s,rims are 7 inch wide,wud b looking for sumin like dunlops X12 all round or similar
Re: liam higgins irish bmw e30Da runs 15s on the Fiat . I'll have a look.
Re: liam irish bmw e30hi liam .
just wondering where u got the roll cage and how much it was, hoping to have a e30 318is track car next week but its only got a sparco half cage. hoping to build it for rallying .. cheers billy
Re: liam irish bmw e30i orderd the rollcage from demontweeks and was about 550 euro delivered to door,mine is an omp but some of them might need towers to be made fit
Who is onlineUsers browsing this forum: No registered users and 13 guests |
