my roadrally 318is
Postby hsr2.6 » Sat Jul 05, 2008 1:18 pm
Is that the new engine kev..........
Postby kevo » Sat Jul 05, 2008 2:43 pm
I'm afraid so, yes it was my new engine....
i'm no expert but i think this may have something to do with it, i'm not sure if it's still in tolerance or not so i'll get it properly measured to see if it's still reusable shortly :roll:
ah well.
Kev
kevo
Postby m3heaven » Sat Jul 05, 2008 6:32 pm
Bad luck there Kevo, really bad luck.
If you want a known good standard M42 as a replacement, pm me and i'll do you a deal you will find hard to turn down......
Postby is-si » Sat Jul 05, 2008 7:14 pm
:idea: bend the other 3 to match?
block and pistons sick then :cry: m3h to the rescue 8)
Postby kevo » Mon Jul 07, 2008 4:10 pm
cheers all, but the blck is fine and dandy luckily, as is the head etc. i've even got the spare rods out of the other lump i took out to replace them with and will be putting them back in when i get chance.
cheers
Kevo
kevo
Postby is-si » Mon Jul 07, 2008 8:35 pm
8) Some good news then , what happened to the piston?
Postby M3 Compact » Mon Jul 07, 2008 8:47 pm
:idea: ....
Postby kevo » Tue Jul 29, 2008 4:44 pm
how do all,
thought i'd have a go at lightening the flywheel, so here it is. i weighed it before and after to get a bit of geek data to laud about :lol:
it weighed originally 9.35kg's
i managed to safely get it down to 6.77kg's
which is a saving of 2.58kg's
or to be even geekier 27.5% less
to balance it i put it onto a grinding wheel balancer and worked my way round till it stopped resting in the same position. it took me a while to do but it's pretty good now. oh and i also cleaned up the face of the clutch as it had gotten very ridged. i'm hoping to get it in soon and will be fitting the shorter ratio e36 box at the same time too.
cheers
Kev
kevo
Postby is-si » Tue Jul 29, 2008 8:03 pm
Thats how engine man lightened jonny sprinters - back face and sides 8) , i'll have piccies soon.
How much did you remove from the clutch face? We have pulled the dowels out in the past and machined to maintain clamping pressure.
Postby kevo » Wed Jul 30, 2008 6:54 am
i was wondering about removing the dowels and skimming it nut i wasn't sure. i took 0.4mm off to clean it up properly, i assumed that shouldn't make too much of a difference unless the clutch was fairly worn and as mine is only about 2000 miles old i left it.
Kev
kevo
Postby jason b » Mon Aug 04, 2008 2:32 pm
Depends on how much you've taken off the friction surface tbh... I've heard of people having big problems after machining flywheels because they overlooked that, but 0.4mm is very little. Just have to see I suppose and adjust as necessary - unless the dowels are easy to get out in which case it might be worth doing in the long term.
jason b
Postby kevo » Fri Aug 08, 2008 10:54 pm
hola,
i've been a busy boy, fitted the shorter e36 gearbox and my lightened flywheel today. went for a spin in her earlier and she's a pleasure! really well geared now and with 14's on she tops out at a ton. and she seems to rev alot quicker now too especially more noticeably at idle, incidentally it still idles like a road car too. am extremely happy, next job putting my scorpion exhaust on to try and extract some noise out of her as hes super quiet, 88db at noise last time.
Kev
kevo
Postby kevo » Sun Aug 10, 2008 8:49 pm
.o
kevo
Postby hsr2.6 » Sun Aug 10, 2008 8:59 pm
Kev your fastly becoming a Mr Meagie of the bmw world.............
Postby elecblondie » Sun Aug 10, 2008 9:08 pm
That's some sweet work. How did you know what to bore it to?
elecblondie
