current mods are...
1 ) bmw z3 steering rack, (after trying the e36 rack and finding it wasn't quite enough).
2 ) full polybush set
3 ) currently running alpina type shocks but will have full challenge spec bilsteins soon when finances allow
4 ) alloy top mounts (home made) on rear
5 ) rear strut brace
6 ) quickshift linkage and weighted gearknob/stick
7 ) weight reduction (27kg's of sound deadening ang speakers removed)
8 ) hydraulic handbrake fitted (home made again) and an extra set of calipers attached to rear arms.
9 ) 325i LSD rebuilt with ford clutch pack and a 4.45:1 cwp fitted.
10 ) quick release aluminium spare wheel post fitted (home made again).
11 ) Aluminium quick release spotlight brackets fitted (you guessed it home made)
12 ) tank guard fitted (home made) and modified original bmw sump guard fitted too.
13 ) interior lights upgraded for plotting
14 ) raised/stiffer springs all round currently budget bits an bobs jobbies although the back end feels great spring wise so that'll be staying when i convert the front end to coil overs (which will be home made of course).
15 ) stud and nut conversio
16 ) z3 diff bush (stiffer than stock)
17 ) modified sump (see pic) although this was replaced due to unnecesscary oil wastage occuring ha ha
18 ) modified and strengthened front subframe which the sump guard bolts to.
19 ) shiny look at me mud flaps fitted.
yet to do...
1 ) fit my front alloy top mounts (home made again)
2 ) make a smaller spring height adjustable coil over kit for front end
3 ) remove sunroof mechanism and seal up permanently
4 ) 18 point safety devices roll cage arriving shortly so will be fitting that.
5 ) battery cut off switch waiting to be fitted
6 ) navigators footrest needs fitting (home made too see pic)
7 ) i'm currently modifying a set of front headlights to take 'h4 bulbs too as it's neccescary for the new road raly rules if i'm to blank of the inner main beams.
8 ) i'm going to make an escort style world cup crossmember for the car and am looking to do something to the gearbox mounts too
9 ) i've currently got a freebee bucket seat and a good set of harnesses to go in so after my cage is fitted they'll be going in to an eventually being replaced by sparco evo seats when i can afford it.
thats all i can think of that i've done so far but i'll keep you posted on it as an when things get done. cheers
kevo
