my roadrally 318is
Postby kevo » Fri Jun 01, 2007 4:42 pm
assembled the one side together earlier and attached my alloy top mounts etc...
and heres a pic of the extra camber achieved by my top mounts...
thats all folks!!
kevo
Postby m3heaven » Fri Jun 01, 2007 5:00 pm
Good show Kevo.......jolly good show.
Postby is-si » Fri Jun 01, 2007 7:40 pm
i like the camber correction, some new paint too makes the job imo. :D
a cover might be an idea to stop water sitting inside the top mounts or v.small drain hole, although your grease nipple will keep the joint rust free, well played.
you can use e46 bad road spring rubbers in the back if you want to pick the back up too. :idea: give us some feed back on your spring rate.
ven bmw rules ze rallying vorld you can be our safari consultant.
Postby m3heaven » Fri Jun 01, 2007 8:36 pm
Good observation.
Send me a PM Kevo for some freebie BMW motorsport turret top covers :D
Postby M3 Compact » Fri Jun 01, 2007 9:14 pm
Excellent again, Kevo. 8)
What struts/inserts are they and where did you buy the coil over sleeve from?
Postby kevo » Sat Jun 02, 2007 6:58 am
how do all,
funny you should mention dust covers i thought of the same thing as soon as i put them on the car so i knocked some up last night....
yeah i was pleased with the ammount of camber i got on should probably make it about standard again now with all that raising going on.
as for the back it's standard car height at the mo with stiffened springs so i'll see how it goes, i know clearance is no issue so far but what are bad road spring rubbers anywho? not quite sure, are they like grayston spring assisters?
as for poundage, i was advised to go for 200lb 14inch long springs, i haven't tried them yet obviously but the other strut was welded last night so i'll hopefully try it sunday after nights again (doing o/t 3-12hrs in a row urggh).
i got the coilover sleeve from a mate i think it was raly design he got them from though? it wasn't really worthwhile making them like i was to tbh, the inserts are challenge spec ones which are 40mm dia pistons with valving for a 325i, the best i could find withouth going silly.
they do look nice with a lick of paint don't they, i'm pleased with them and glad to be working on her again too, i just pm'd you m3 heaven - i'm intrigued and grateful :D
kevo
kevo
Postby rearwheelsteercompact » Sat Jun 02, 2007 10:02 am
Nice to see you 'back on it' Kevo - inspirational 8) 8) 8)
Postby kevo » Sun Jun 10, 2007 4:45 pm
many thanks to m3 heaven, just received the strut top mount covers they'l go on a pleasure! i've got a couple of silly little bits to go on in the next few days i'll keep you posted.
kevo
kevo
Postby is-si » Sun Jun 10, 2007 8:10 pm
bad road spring rubbers are the rubber pads that go between the rear wishbone and the spring. They all vary in thickness, but `bad road package' E46 ones are something like 16mm thick, so they give you something like 30mm extra ride height.
Postby kevo » Tue Jul 03, 2007 3:06 pm
well hello,
been a while, but heres some pics of my latest job. ramp angles. been reading all about them and thought i'd have a go, still yet to put them in the car but when i do i'll let you know the results be they good or bad. as for concerns about the overall height being affected well the measured height of the section you see with the calipers on before was 40.5mm and now is 40.4mm so the height is reduced but only by 0.2mm overall which i don't think will be too much of an issue personally, but we'll see.
kev
Image[/img]
kevo
Postby Sunbmw » Tue Jul 03, 2007 9:00 pm
Well done Kev, that may just be the way around it.
How did you machine them by the way???
http://www.m3spares.com
http://www.ultimateid.co.uk
Sunbmw
Postby M3 Compact » Tue Jul 03, 2007 9:35 pm
Sunbmw wrote:Well done Kev, that may just be the way around it.
Yes, very interesting. 8)
Good work again Kevo and thanks for sharing. 8) 8) 8)
Postby kevo » Wed Jul 04, 2007 7:00 am
hi all, i looked into spark erosion as one way of doing it this also had the benefit of being able to make uneven ramp angles for deceleration and acceleration, but as i don't know enough about that to decide angles etc then i thought i'd do them standard. in the end i opted to surface grind them they didn't prove to be too hard although they did take some serious setting up as the four tabs you see round the od of the plates aren't in line with the slots which made it alot more difficult to set up as each one had to be done individually for each ground edge! took a good few hours setting let alone grinding but there we are. oh and that was after i had to make a jig to hold the plates at tye correct angle too. lets hope it was worth it.
kev
kevo
Postby kevo » Thu Aug 02, 2007 11:16 pm
aloha again,
i've made the decision now regarding my engine and i'm gonna build myself a nice fresh m42, lighten the flywheel an stick an e36 318is box on it which combined with my diff should give me about 100mph flat out and a nice bit of acceleration. i may lighten and balance the thing too depending on how much it costs an i'm looking into getting it setup properly with some sort of chip on a rolling road or poss megasquirting it. in the mean time here's my progress for this evening...
i didn't get a photo of the engine completely assembled but i'm sure you know what that looks like anyhow
not really too much to see generally but it's always nice to get a before and after shot eh? oh below you can see what 100,000 miles does to a bmw block... absolutely nothing! it's still got the factory cross hatching in there so i'm not even gonna glaze bust it.
if any of you have heard about a profile gasket failure and aren't sure what it is heres a picture of a failed one. this thick rubber gasket had corroded away and led to the coolant being lost in quite an awkward place to detect.
the first thing to do once i make a tool for getting the crank bolt out, (bloody tight!!!) is i'll be stripping the block completely and sending it away to make sure it's not cracked and is sound. i've learned this by my mates mistake who has just fully assembled his pug 205 replacing his old cracked block with a nice shiny new cracked block. not a happy man. i'll keep you posted anyway bye for now.
Kev
kevo
Postby M3 Compact » Fri Aug 03, 2007 12:33 am
Awesome. 8)
I'm investigating an Oxford Dictionaty application atm, it involves a change of spelling the word HERO, replacing the H & R with a K & V. :!:
M42/M44 project starting here very soon, Kevo. :P
All info very helpful. 8)
